need help finding serial number
novice guy
11-28-2006 04:11:20
New to the forum and antique tractors,and this is probably a stupid question but.. my "new" super c is dying out when i give it gas, i want to replace the carbuerator but i can"t find any serial numbers on the carb, or on the tractor (the tool box is gone)please help the novice! and here's one even dumber..three of us have looked and we can't find the oil dipstick!
Patrick in Illinois
11-29-2006 08:58:48
 Re: need help finding serial number in reply to novice guy, 11-28-2006 04:11:20
As far as your carb, switch it to a Zenith carb;works better. Probably can get one from this site. My opinion. Patrick (owner of a 51 Super C with a ZENITH carb).
J.J. from Afton
11-28-2006 22:02:28
Actually even the very early F-12 IH blocks had a dipstick, and no petcocks on the oil pan, such as the block in my 1934 F-12
Keith-OR
11-28-2006 06:48:46
novice guy, the serial # tag would be on the tool box for Super C. Since yours does not have the tool box, the engine serial number will be close but not exact. Engine serial # will be under #1 spark plug(front plug, closest one to the radiator) on the block and slightly forward, stamped on the flat machinced surface. You might have to scrape off paint, rust and anything else that might be covering up the #....HTH
Keith & Shawn
novice guy
11-28-2006 14:54:31
 Re: need help finding serial number in reply to Keith-OR, 11-28-2006 06:48:46
found the engine serial number stamped on the plate by plug #1 thanks. also i found the two bolts to check the oil with thanks again! Here"s 2 more stupid questions #1 what type of oil do i use? #2 my carbuerator is a Carter model UT anybody got one of them? Isf so where do you get rebuild kits for it?
Brownie 45
11-28-2006 05:22:49
Sorry, Nat. You were posting while I was typing.
Brownie 45
11-28-2006 05:20:11
Should be two oil checks on the side of the oil pan. Oil level should be between the upper & lower checks. Loosen by turning left-hand & oil should drip out if oil is at that level. Carb number should be on a brass disc riveted to upper surface of carb.
Nat 2
11-28-2006 05:16:11
The serial number should be on a silver tag riveted to the bell housing near the junction between the "transmission" and the engine.
Nat 2
11-28-2006 05:15:21
There is no dipstick. IH didn't invent the tractor engine oil dipstick until 1957.
You check the oil using the two petcocks on the side of the oil pan under the engine. If the oil doesn't run out of the top petcock, but runs out the bottom petcock, you have enough oil.
JayWalt
11-28-2006 07:55:54
 Re: need help finding serial number in reply to Nat 2, 11-28-2006 05:15:21
I beg to differ, my 300u is from 55 and it has dipstick plain as day...
john cub owner
11-28-2006 06:21:31
Actually IH did have dipstick tractor engiens available in 1947 (cub), but didn't change the design of existng blocks to accept them unless other major changes were made requiring casting changes.
neblinc
11-28-2006 05:13:31
Click Below.
Randy
novice guy
11-28-2006 14:59:52
 Re: need help finding serial number in reply to neblinc, 11-28-2006 05:13:31
hey thanks! it looks like my "c" is a 1952 from the engine serial number i found appreciate the help
novice guy
11-28-2006 14:59:47
