O/T Model A Axle
SuperA-Tx
11-30-2006 16:20:42
I have this axle from a Model A pickup and I want to make a two wheel trailer to pull behind my tractor because I like the wire wheels.
On the inside of the wheel hubs are four botls that appear to hold the wheel hubs to the axle. They have castle nuts, four on each one. I removed the nuts and I thought the wheel hubs would cone off the axle but it doesnt. I can get a little gap between the hub and the axle but just enough to get a crow bar tip in there and then it dont budge. The bolts are loose and could be pushed into the hub so I know they arent binding.
This is my first time at doing anything like this so could someone tell me what I am doing wrong or what I havent undone?
Ron in Nebr
11-30-2006 17:08:23
 Re: O/T Model A Axle in reply to SuperA-Tx, 11-30-2006 16:20:42
Sounds like you took the nuts off that hold the brake backing plate to the spindle.
Take the dustcap off on the outside of the hub and remove the cotter key and then the big nut that holds the bearings. Then slide the hub off the spindle. That'll get you to the brakes and those bolts you loosened.
Gotta say though, they just flat ain't making Modle A Ford axles anymore. I understand you like the wires, and sometimes a guy needs to make do with what's laying around....but I'd bet you could sell that axle and original model A wire rims to a restorer for more than enough to buy a regular trailer axle and whatever kind of rims you want to put on it. Seen just a set of rims go on ebay a few weeks back for about $150. I just pulled apart an old farm wagon with '36 Ford axles under it- gonna be a moneymaker for sure.
Also, those Model A wire rims are liable to be 16 inchers.....that'll take darn narrow tires. Be sure, if you follow your original plan, that you can get tires for your rims.
Whichever way you go- it's yours, good luck!
Tom Windsor
11-30-2006 22:39:23
 Re: O/T Model A Axle in reply to Ron in Nebr, 11-30-2006 17:08:23
Please do not put these wheels on your trailer. As has been mentioned, they just "ain't making these anymore."
TW
SuperA-Tx
12-01-2006 10:19:47
 Re: O/T Model A Axle in reply to Tom Windsor, 11-30-2006 22:39:23
Tom,
I slill have one axle with the tie rods still on it. Any of yall that are close is welcome to it if you want to come get it. I tried it out and it steers fine.
The wire wheels...two are good and two are pretty rusted around the valve stem. Ill use the two good ones and keep the other ones unless someone wants them. I think they will take a 4" X 16" tire.
Leroy
11-30-2006 17:39:59
Model A wheels were 21" for 28 & 29 models, 30 & 31 had 19" wheels, the 16" wire wheels were from a 32 to 34 Model B or V8, and someware along the line I understand there were some 17" wire wheels as well. All sizes that are hard to find.
Duner Wi
11-30-2006 18:15:55
 Re: O/T Model A Axle in reply to Leroy, 11-30-2006 17:39:59
I could be wrong but I am thinking 18" for 32.
17" for 33-34 and 16" for 35. The A's are correct as far as I know. These wheels got moved around alot due to war shortages of tires.
SuperA-Tx
11-30-2006 17:34:33
Ron,
Heres a pic but I think you told me what I needed. I havent messed with the caps but just cleaned em off while I was waiting.
Honest, I had already bought a small trailer but wasnt happy that it didnt fit thru the doors at my store where I keep the tractor. The axle was from an old trailer we used at the farm to haul out plants but had been sitting in the woods for 20 years. I hate to throw things away but the wheels are so rusted I think I can only salvage two out of the four and thats only after patching.
Yes! 16 inch wheels and the tires that were on there were to small and like to have never came off. Good suggestion, will check if the tires are available.
I restored the tractor that was my fathers that he started the business with. This old trailer was used on our farm for as long as I can remember.
I'll still have the axle, I have two, they are yours if ya want em.
third party image
Ron in Nebr
11-30-2006 21:45:07
 Re: O/T Model A Axle in reply to SuperA-Tx, 11-30-2006 17:34:33
"they are yours if ya want 'em"
Thanks! That's a nice thought but actually shipping 'em up here to NE would probably eat up more money than I could make selling them....they's kinda heavy! It's the wire wheels that are worth more, if they're in good shape.
Just for fun, go to ebay and type in some searches for Ford wire wheels, and Ford axles...oughta give you an idea of what they go for.
Also, if you don't know any "old car guys", next time there's a car show in your area, go look for anyone that has any old Fords('49 and older, earlier the better), tell 'em what you have(don't forget to mention the hydraulic brake backing plates since they're sought after) and I bet one of them could take those axles off your hands for a decent price.
If all else fails, next summer when ya get too hot in TX, throw them in and take a road trip north- I'd be glad to have 'em!
Leroy
11-30-2006 17:48:55
I don't think your axles are Model A but 32-34 V8 axles and those brake drums to take off press out the lug bolts and the drums will come off and better without them on a trailer. Any standard 5 lug implement wheel will fit those hubs as well as 41-48 car or truck rims in the 16" size and some early Mercury 15" rims fit as well as the 4 wheel drive 1/2 ton ford truck rims or IHC Scout or Jeep rims. Have lots of those old Ford axles under my wagons.
Wardner
11-30-2006 18:43:39
 Re: O/T Model A Axle in reply to Leroy, 11-30-2006 17:48:55
I have a '32 Ford and those are not the same hubs and brakes although the bolt pattern is. '32s used 18" wire wheels and a cast drum/hub. '33 used 17" and I think '34 used 16" wire wheels. Anyway, all those tires are available thru places like Coker Tire. The 'B' and 'C' four cylinder Fords used the same tires as the V8. There was a brief period in the '30s ('37 and '38 ?) where Ford got away from the 5.5" (?) bolt circle. The wheels are sometimes called "speed wheels" and have a bolt circle of around 12". I have some of those brake drums and wheels laying around.
The Ford spoke wheels have a tendency to break spokes. You should rap each spoke with a light hammer and listen to the tone. They should all sound the same.
If your are using a rear axle, you need to understand that the end of the axle shaft is tapered. The hub has to be pulled off the axle. You will see an annular notch where a special puller grabs the hub. Once tension is applied, a swift blow with a 2 pound hammer on the puller screw head will pop them off.
Wardner
11-30-2006 18:54:40
 Re: O/T Model A Axle in reply to Wardner, 11-30-2006 18:43:39
I looked again at the picture and I don't know what you have. That's a front hub and what looks to be a tie rod. However, the axle appears to be tubular vs I-Beam and would indicate a rear axle. You can't mix the two together. Anyway, you don't need the puller. Pry off the dust cap, extract the cotter pin, remove the large nut, and the drum and hub will come off if the brake linings are not "welded" to the drum. They probably aren't.
Allan In NE
11-30-2006 18:01:26
I agree with Leroy,
That's no Model A axle.
Allan
SuperA-Tx
11-30-2006 18:20:40
 Re: O/T Model A Axle in reply to Allan In NE, 11-30-2006 18:01:26
Allan, Leroy,
Yall might be right.
I have been told several things. Some say they are off a Model A pickup and some say other things. All I know is that the hum cap covers said V8. But two guys said those were just covers that were added and the wheels were off a Model A. Frankly I dont even care, I just like the wheels/rims.
Anyway I got it off now and cleaning it out. It was full of dirt dobber nests.
SuperA-Tx
11-30-2006 18:28:33
 Re: O/T Model A Axle in reply to SuperA-Tx, 11-30-2006 18:20:40
A differant view.
third party image
Wardner
11-30-2006 19:02:16
 Re: O/T Model A Axle in reply to SuperA-Tx, 11-30-2006 18:28:33
This picture clearly shows a hydraulic backing plate. That indicates a '39 to '48. However, those plates can be adapted to any Ford car and light truck from '28 to '38. The sweep of the I-Beam indicates later rather than earlier. I can't see the spring perches and that would narrow down the guess on the year.
Ron in Nebr
11-30-2006 19:53:34
 Re: O/T Model A Axle in reply to Wardner, 11-30-2006 19:02:16
Yep, like Wardner says- hydraulic brakes are 39 up. Looks in the picture like the spindle was just welded solid to the axle, so that'd take a bunch off the resale value to collectors(although it wouldn't be impossible to grind off the weld and make it look original). I'd say if you can find wheels and tires to fit, go ahead and make your trailer out of it. Someday in the future the value of the axle regardless of the weld might make it worthwhile for someone to buy it from ya....in the meantime, making your trailer, try to just bolt everything together without any additional cutting/welding on the axle.
Thanks to all the others on the info regarding the old Ford wheels sizes....I wasn't sure, just knew that the big pile of early Ford wirespokes I've accumulated were all 16 inchers.
Wardner- those big bolt pattern '38 wheels are what the racecar guys run(they call 'em "wide 5's) and often they'll buy some original narrow wheels to mount tires on so they can load their racecars on narrow trailers. Seen that alot....although I have to admit I've hauled a pair of those wheels to several racing swap meets without selling 'em.
SuperA-Tx
11-30-2006 19:46:53
I think they are of a earlier year. Someone said "the earlier year wire wheel spokes were welded but the later ones had holes drilled and the spokes went thru the center and were bent". Mine are welded.
I got them apart pretty easy after I undid the dust cover thing. About a quart of dirt in each one.
Checking on tires tomorrow before I go any further.
Thanks guys. Yall have been a lot of help.
Randy
Wardner
11-30-2006 20:45:47
 Re: O/T Model A Axle in reply to SuperA-Tx, 11-30-2006 19:46:53
Let me just say that your hardware could have come from a Model A pickup. That's only because someone updated that truck. Your pictures show hardware that was iron ore when the Model A was built.
For instance, my '32 pickup has '46 brakes, '41 rear end, '39 tranny, a shortened torque tube from the middle '30s, rear cross member from some later Ford, steering box from I don't know where, and a '62 (?) Mercedes 220 Diesel. I did all this work 40 years ago with the exception of the Diesel which was done about 30 years ago. Before that it had a '51 Mercury engine followed by a 283 cu in Chevy. It also has three extra leafs in the rear spring. I retained the original wheels and one has to look carefully to find the changes. It appears stock and sounds like something Ford built. It is an altered vehicle but not a hot rod. That was part of the allure of the early Fords. They were easily modified.
I made all these changes to beef up the load carrying capacity of the truck. I built a oak and ash ice cream vending body complete with compressor, cold plates, and soda fountain. It was very heavy. In the winter, I ran it with the pickup body and used it everyday until 1981. It only needs a battery to drive it out of the barn. I don't have pictures but I can take and post some.
Everytime I broke something, I made it stronger.
Ron in Nebr
11-30-2006 21:29:02
 Re: O/T Model A Axle in reply to Wardner, 11-30-2006 20:45:47
Wardner, the original definition of a "hot rod" back in the '50's was "a vehicle that has been modified to improve speed OR performance".....your's has for sure been updated performance-wise, as in being able to better perform what ya want it to do! But, if you ever read the "hot rodder" magazines, there's a constant battle over how they think they oughta classify whatever vehicles they're working on.....we can leave that to them and just call yours "improved" or whatever you prefer.
That being said- I'd MUCH prefer to see one with the actual "working" modifications that you've done rather than a "show queen" with unfunctional chrome crud slapped all over it. Please post pics!!! If you decide to post them over on the "classic trucks" forum, where they probably oughta be, at least post something here to let us know.
From a fellow 650D owner..... .
Allan In NE
11-30-2006 16:31:27
Whew, long time ago.
Don't ya have to take that center nut/hub/thing loose?
Can't remember,
Allan
City-Boy McCoy
11-30-2006 16:27:27
1) Front axle or rear axle?
2) Brake drums or no brake drums on hubs?
mike
