moving a 300U
Bill Geer
11-30-2006 21:19:49
I have a 300U that I need to tow (with chain) about 5 miles. Will doing this screw up the T/A? Do I put the T/A lever forward or back?
This is a non running tractor.that I got for 200.00 + old snowmobile.
Ksfarmmer
12-01-2006 19:44:38
 Re: moving a 300U in reply to Bill Geer, 11-30-2006 21:19:49
I don't think you should hurt the T/A either way since you will be pulling it in neutral, but just to be sure I would leave it forward/direct drive (away from the operator). If you can't find a trailer, I would strongly recommend that you pull it with another tractor in a lower gear ie third or fourth if you have an old M or H. If you must pull with a truck don't go over 5 mph. Don't ask how I know.
bm3501466
12-01-2006 06:50:43
This doesn't apply if you are neutral, but if you have to pull start it NEVER have the TA in the engaged position. The engaged position is closest to the operator and the rear. Forward is high range which is just the regular rear end.
Bill46
12-01-2006 05:03:31
Don't tow it...haul it. If you go too fast you may dammage the thrust washers in the transmission and it will not go in gear. Did that once on a Super H which is basically the same drive train.
Put it on a trailer and be safe.
Bill Geer
12-01-2006 02:10:47
Hi Old Because it dosent steer good I will be putting the frount on a tow dolly used for cars. Real slow 5mph.
witch way for T/A lever forward or back? Thanks Bill
workhorse
12-01-2006 05:30:09
 Re: moving a 300U in reply to Bill Geer, 12-01-2006 02:10:47
put the rear wheels in the dolly, tie the stearing wheel and go as fast as the tires will allow.
maplehillfrm,pat
12-01-2006 04:54:56
I believe the TA goes towards the rear,, not sure if it will screw anything up being dragged that far,,is this a wide front?? ,if its narrow how ya gonna keep it from tipping,,,i'd spend the 50 bucks and put her on a trailer a lot less headaches, and safer for the other guy,,,
Nat 2
12-01-2006 05:02:14
 Re: moving a 300U in reply to maplehillfrm,pat, 12-01-2006 04:54:56
Actually it doesn't matter.
With the transmission in NEUTRAL, the TA section isn't turning.
old
11-30-2006 21:31:58
If I where you I would use a trailor even if you have to rent one. We hauled a 300U on a 16 foot car hauling trailor with no problems. Biggest reason isn't that it will hurt the TA but because of safety and brakes not working well on the tractor
