super h will run a little will then blow a conden
na na
12-02-2006 10:50:35
have a 1953 super h it was starting fine this fall. now it wont start keeps blowing condencers. changed the coil, points ,cap. when we do get it running it last maybe an hour. help if you can
Hermit
12-03-2006 18:06:49
 Re: super h will run a little will then blow a co in reply to na na , 12-02-2006 10:50:35
If you're sure the condensors are blowing, have you checked the inside of the dist. cap for carbon tracks? You may have high tension voltage somehow making its way to the condensor and frying it. Good luck.
voager213
12-02-2006 15:34:23
i dont want to sound stupid but you might want to try converting to eletric ignition- have not tryed to do this yet but when my points go or condencer i am going to put electric ignition into my h
BIG JOHN
12-02-2006 11:27:06
If your tractor has been converted to 12v and you don't have a "Balast Resistor" between the feed and your coil. You will be feeding 12v directlly thru your coil to the condensor which is a 6v condensor.
Bob
12-02-2006 11:58:31
 Re: super h will run a little will then blow a co in reply to BIG JOHN, 12-02-2006 11:27:06
The breakdown voltage of the condensors is in the 200 Volt to 600 Volt range, whether for a 6-Volt or 12-Volt ignition system.
If there is no ballast resistor used, and one is needed, primary current will be excessive, shortening breaker point life. However, the condensor shouldn't be affected.
Bob
12-02-2006 11:14:22
You've either fallen into a bunch of bad condensors, or there is something else wrong... poor connection or short in that distributor that is momentarily "repaired" when you wiggle things around to replace the condensor.
Have you ever tried putting one of the "bad" condensors back in, to see if it "works" again, for a while?
If, in fact, the condensors ARE failing, where have you been getting them?
Try a CNH, Blue Streak, or NAPA Premium condensor.
