what will fit?
tn terry t
12-07-2006 10:55:00
what model tractors starter will bolt to a super a i dont care about the selenoid i can rig up somthing
tn terry t
12-07-2006 19:03:33
 Re: what will fit? in reply to tn terry t, 12-07-2006 10:55:00
thanks guys got another old a without a starter and its kinda hard to pull start it by myself. my sholders wont let me crank start it. just want to see if i can get it to turn over
NDS
12-07-2006 12:28:46
Any non super, non diesel, letter series will bolt up and work on Super A. First series Super M will also work and probaly Super C and some Super Hs. I have A, M, and SM starters will interchange on all of them, A has solenoid.
gene bender
12-07-2006 17:03:15
 Re: what will fit? in reply to NDS, 12-07-2006 12:28:46
The ones for an H or M will have the threaded post. One for a SA has the button at the rear of the starter for a pull rod it would be the same starter for the C and SC. The SA does not need a solenoid nor does the A,B,BN,C,SC,H,M,W series.
NDS
12-07-2006 17:59:13
 Re: what will fit? in reply to gene bender, 12-07-2006 17:03:15
When starter with threaded post is used on A you need a solonoid or some other type switch. tn terry implied in his post that he was not concerned with being correct and that he could "rig somrthing up".
Will Sick
12-07-2006 12:17:01
I'm quite sure that you can use a starter from an H or M. You ,like you said,would need a selinoid or a push switch at a different location.
gene bender
12-07-2006 11:54:28
Your best bet would be a new one from a place in MINN he has new ones for 115 pluss shipping no core needed he also has the sw for around 10 add the pull rod and you are in busuness. this uncludes a new bendix. you can spend a lot of money on a used one that may be half shot.
