H Pulley lubrication
Tom Windsor
12-09-2006 14:14:48
I am not sure whether the gears for the pulley are oiled from the transmission or have a separate reservoir. Seems to have a filler plug in the attachment area.
tw
Tom Windsor
12-09-2006 17:49:19
 Re: H Pulley lubrication in reply to Tom Windsor, 12-09-2006 14:14:48
Thanks Bill and Randy.
Randy as in Randy-IA
12-09-2006 14:40:46
Hi Tom , Yes on both questions . It does have a filler on top to add a little oil . It's only used if you remove the belt pulley for any reason and dump the small amount of oil in it's reservoir out . Otherwise it's oiled by gear splash from the trany gears . Take care ...Randy
no tools
12-09-2006 14:39:34
Tom it has a filler plug but it gets oil from transmission.
if you have had it off and drained it i would put a little back in the plug.
just to ease your mined.
Bill
