H NOT RUNNING WELL
JIM/WISC
12-12-2006 16:49:08
MY H TRACTOR RUNS ROUGH WHEN I OPEN UP THE THROTTAL, IT WILL RUN SMOOTHER AFTER A SECOND OR 2. I HAD THE CARB REBUILT AND ADJUSTED AND NEW POINTS,CONDENSER,CAP,ROTOR ALL DONE BY A REPAIR SHOP,DID A COMPRESSION CHECK(LOOKS VERY GOOD) BUT AS SOON AS I GIVE HER THE GAS , SHE STARTS TO SOUND LIKE A POPPIN JOHNNY, ANY IDEAS? COULD THE GOVENOR BE THE PROBLEM.
Farmall Ed
12-13-2006 06:05:19
 Re: H NOT RUNNING WELL in reply to JIM/WISC, 12-12-2006 16:49:08
Does the choke make any difference? My H was running as you describe and I found the little screw that holds the choke plate on the rod had sheared letting the plate flop around. Like to drove me nuts for a while. The screw was a pain to get out but luckly I had a spare in an old carb kit. Ed
luther
12-13-2006 05:58:35
Check for leaks in intake Manifold.
RustyFarmall
12-12-2006 21:13:35
Are you letting the engine warm up a bit before you pull back on the throttle? Spitting, sputtering, and missing is perfectly normal with a cold engine.
CNKS
12-12-2006 19:45:45
Depending on who rebuilt the carb, they might not even know the settings. Warm the tractor up. Set at wide open throttle, turn the main mixture needle in until it just begins to run unevenly, then out until it runs smooth, plus maybe a 1/2 turn. No need to turn it out until it smokes. You want the mixture lean, or just rich enough so that it performs well under load, no more. Do the same to the idle mixture. Pull the throttle back rapidly, if it does not accelerate smoothly, do the main and idle again. If it still will not accelerate smoothly, your carb was likely not rebuilt properly. This assumes no ignition problem, no intake manifold leaks, etc.
old
12-12-2006 17:28:43
Differant times of year also can mean haveing to reset the main jet or you can have problems. Try turning the mani jet screw out about 1/2-1 turn and see if that helps. Also another way to set it would be to turn it out till you see black smoke and then turn it back in till the smoke stops.
teddy52food
12-12-2006 17:00:22
Tom, that should be OUT 1/2 turn.
Tom Windsor
12-12-2006 19:08:59
 Re: H NOT RUNNING WELL in reply to teddy52food , 12-12-2006 17:00:22
Yep...
P Backus
12-12-2006 16:58:46
Usually caused from running too lean. The H carb doesn"t have an accelerator pump to take care of the problem. You could richen up the mixture, but don"t make it smoke (too rich) all the time. In my experience, using the tractor all the time and fresh gas will aleviate the problem.
Paul
Tom Windsor
12-12-2006 16:55:47
"I think" that you should turn the adjustment screw on lower right of the Carb in 1/2 turn.
P Backus
12-12-2006 17:00:58
 Re: H NOT RUNNING WELL in reply to Tom Windsor, 12-12-2006 16:55:47
Tom, I"m not 100% sure, but I think you"d need to turn it out to richen the mixture a bit.
Paul
Tom Windsor
12-12-2006 19:10:56
 Re: H NOT RUNNING WELL in reply to P Backus, 12-12-2006 17:00:58
Your are right...brain been mostly dead all day...
JIM/WIS
12-13-2006 03:10:44
 Re: H NOT RUNNING WELL in reply to Tom Windsor, 12-12-2006 19:10:56
THANKS FOR THE ADVICE, I WILL GIVE THE CARB ADJUSTMENT A TRY
