Farmall H restarting problems
marticus
12-24-2006 08:12:31
I have a '46 Model H with an H4 mag. It will start right away but after it runs and I shut it off, It won't restart. Go out a few days later and same thing. Any suggestions where to start. Is this something with the mag that once its warmed up it has an issue.
Hydro
12-24-2006 10:08:30
 Re: Farmall H restarting problems in reply to marticus, 12-24-2006 08:12:31
I had the same problem with my M,after much troubleshooting I finally installed a spare mag.The tractor ran and started perfectly. I suspect the coil was bad and it would provide spark when cold but not when hot. Maybe magman could give us his thoughts.
RP-40-9n
12-24-2006 10:03:26
i have seen timeing being off will cause this problem. RP
voager213
12-24-2006 08:38:46
do a compression test on the engine ive seen theis alot in engines when the compression gets to low after you start the engines things expand causing a loss in compression when everything coolsdown you can start it again then u shut it off and bam wont start again
kfox
12-24-2006 08:29:10
Keep a good sparkplug handy, and when it wont start pull one of the plug wires and use your handy plug to check for sparks when you crank it over. If you have fire at the plug, this will rule out a fuel problem. ken
kfox
12-24-2006 08:32:32
 Re: Farmall H restarting problems in reply to kfox, 12-24-2006 08:29:10
I ment to say this will indicate a fuel problem if you have fire at the plug. (its hard to do this internet stuff with a 2 year old Great Grandson setting on you lap :-) )
Janicholson
12-24-2006 10:27:16
 Re: Farmall H restarting problems in reply to kfox, 12-24-2006 08:32:32
But it is a good thing!! JimN
