Farmall 400 Battery
Kyle Bailey
12-25-2006 09:10:40
Hey guys, I've got a question about the charging system on the farmall 400s. Is the tractor a 12v positive or a 12v negative ground system. It is hooked up as a 12v positive ground system but I'm not sure if that is right or not. It was my grandfather's tractor and I haven't done much with it so I'm not very familiar with it yet.
jeffcat
12-25-2006 11:08:43
 Re: Farmall 400 Battery in reply to Kyle Bailey, 12-25-2006 09:10:40
Also --- to crank that big bad girl over you need one of those spiral wrap batteries. They have tons of crank amps to spare. If the amp gauge is reading the right way around then leave it alone. Jeffcat
Nat 2
12-25-2006 19:38:19
 Re: Farmall 400 Battery in reply to jeffcat, 12-25-2006 11:08:43
No, you don't need one of those expensive spiral wrap batteries. They crank over just fine with plain old tractor-duty batteries, provided you use good cables and the connections are kept clean.
RustyFarmall
12-25-2006 09:20:05
If it is working the way it is. Leave it that way.
Adam R
12-25-2006 09:16:23
If the tractor is chargeing properly and sitll has the 12v generator on it, the battery is probably hooked up right.
My 450 was 12v pos ground til the gen went south so I threw in an alt and swiched a couple wires around and it is now 12v neg ground.
Adam
