Injector pump Super MTA
Farmalls the Be
12-30-2006 17:41:29
On my Super MTA diesel. My governer surges or lopes while idleing but works perfect in any other throttle position. I have a tech manual and have set all of adjusting screws to spec. What could my problem be?Any help is greatly appreciated.
the tractor vet
12-30-2006 21:53:07
 Re: Injector pump Super MTA in reply to Farmalls the Best, 12-30-2006 17:41:29
I think that you will find that the bushing on the cam are shot and the pump is due for a rebuild and i'll lay a dollar to a donut that when ya check the oil in it ya find fuel in the crankcase of the pump. so it is time to remove the pump and send it into a GOOD diesel shop and have it rebuilt but word to the wise here best make sure that they know that old pump as it has some quarks and it take a good OLD pump man to get them wright.
chuck46
12-30-2006 19:40:04
Hi, Problems at an idle are usually with the pump plunger unit. Unless you have experience and test equiment take it to a good diesel mechanic. Good luck, Chuck
