504 eng serial location
Gary_N_WV
01-04-2007 18:51:09
A buddy of mine has a 504 gas utility with a blown head gasket and needs to find the engine serial to get the proper gasket of the 2 different ones that can be ordered at the local auto parts store.
Where would the engine serial be located?
Thanks
Gary
Weldon K
01-05-2007 18:47:52
 Re: 504 eng serial location in reply to Gary_N_WV, 01-04-2007 18:51:09
Operator's manual shows serial number of gasoline engine to be on the side of the block, a couple inches or so above the distributor. Look for a smooth machined surface about three quarter inch wide and 2-3 inches long in that location. Number will be stamped into metal of the block.
I can send you photo from manual if you need it.
