Mounting battery box on an H
Lincoln
01-08-2007 19:30:12
I ordered one of those new reproduction battery boxes for my Farmall H. I looks like in the parts book the bolts that hold it to the brackets should stick down from the inside of the box. Since you have to put the battery in the box before putting the box on the tractor, how are you supposed to hold the bolts to tighten them with the battery sitting on top of them? Or worse yet how would you ever hold them to loosen them after they have been there for awhile?
Allan In NE
01-09-2007 04:41:02
 Re: Mounting battery box on an H in reply to Lincoln, 01-08-2007 19:30:12
Yep,
Toolz has it. You have to use old fashioned, square headed "farmer bolts". :>)
Allan
toolz
01-08-2007 20:22:45
The proper bolts have square heads that fit into the slots in the bottom of the box. You leave them a little loose, slide the box in (after installing the battery) and them snug them up. The slots keep the bolts from spinning.
