fast-hitch with traction control
jk
01-12-2007 15:09:06
i have 2 HI utilitie, both with fast-hitches and "traction control". can anyone tell me how to use the traction control or what it was desinged for? i don't know how to use it, the "proper" use, or how to test and see if it works. i do know that both control handles and all the way down (the last notch closet to where you put your hand on the lever to adjust it), does that mean anything? also, witch 460 utility pump is the 17 GPM version, cessna or thompson? thank you
jk
jk
01-14-2007 15:12:16
 Re: fast-hitch with traction control in reply to jk, 01-12-2007 15:09:06
thanks for the info. i don't plow so i really don't thik i will need to use the traction control. i was told it does not work on the 460U ayway. i have a 12 GPm hydo pump on my 460U and would like to update to a 17 GPM, witch on is the 17 GPM cessna or thompson? thanks jk
Larry806
03-07-2009 07:28:27
 Re: Friendly message to Dwight selling the Super C in reply to mkirsch, 03-06-2009 19:42:49
I've advertised the same way . As said below I can get more in parts .
What I call common tractors , Farmall C , H & M 's JD A & B's are hard to make any money on unless I part them . I have a 51 JD A I bought thinking I have the parts it need's . After I got it home I remembered that the parts I
need went in the last scrap roll off we sent out . Now I could offer it for sale needing a few things or I'll cut it . About the best I can do selling it whole is break even . Parting it with 4 hours work I can make money .
kfox
01-14-2007 12:19:43
 Re: Origional Parts in reply to IaGary, 01-14-2007 10:58:04
third party image
Your right....That wasn't a very clear topic. I bought this old H last year out of the boneyard because it had a M&W 9 speed tranny. The tractor had set for over 20 years with a stuck engine before it ended up in the junkyard. The fanbelt picture is a "after, or during " photo. This is a before photo taken the day I found it.
CNKS
01-13-2007 19:58:01
 Re: Web Page in reply to Randy as in Randy-IA, 01-13-2007 16:46:40
I mean software such as Red Power Magazine uses. No advertising allowed. It is an easier site to use than this one by a long way. seldom hangs up. You do have to have a user name and password. But once the site accepts it, you don't need it anymore. I don't even know what mine is.
RAW in IA
01-12-2007 16:18:17
Dad had a 350 witha 3-16 fast hitch plow. We kept the handle all the way down. Dad tried it at different settings but did not like how it worked. so left it down, which basically disables it. Controlled the plowing depth, etc . with the hydraulic lever. Spent most of the time with one hand on the hyd. lever. Finally he bought a 3-16 pull type plow, and said it pulled easier then the fast hitch one.
Berry450d
01-12-2007 15:36:06
When plowing be sure and remove pin on bottom cylinder so hitch will float, or it will jack tractor up, and cause to spin out. We tried plowing with 230 and did not know this. Couldnt plow 3 inches deep.
Janicholson
01-12-2007 15:18:17
The main method is to experiment with it. We used it on a 350U when plowing. We found it to be best adjusted at one notch from the handle (untill we changed the points and shares on the plow) Then it needed an additional notch farther up. I believe it is effective, butrequires experimentation. JimN
