Using radiator covers?
tractorsam
01-14-2007 13:11:16
I seem to posting on here rather a lot lately, my thanks to everyone for the good advice. I've started using a cover for the radiator on my Super C to try and help it warm up faster/better. I've yet to see the temperature gauge move and I'm unsure if it even works. What indicators might I get (presuming the gauge isn't working) that would let me know I'm getting it too warm and need to expose some of the radiator? Thanks again, tractorsam
Dr.EVIL
01-15-2007 08:56:17
 Re: Using radiator covers? in reply to tractorsam, 01-14-2007 13:11:16
Watch the oil pressure gauge....at low RPM when the oil gets hot it thins out and PSI would drop. Unless Your working Your tractor Really long & hard I doubt You can overheat it just pushing a little snow.
Brownie450
01-14-2007 13:53:13
If the temp doesn't come up, the thermostat retaining "wire" has possibly slipped out of its groove & let the thermostat move up in the outlet pipe. Happened to ours a time or two.
gene bender
01-14-2007 13:42:35
these cooling systems are pretty good. Why dont you use a cooking therm to see what the coolants temp is when warm. You could being verry careful take the sender out and put in a cup of hot water and check the guage along with a thermomenter then you would inow if the guage is ok. Thats what i do. But the simple test is a therm in the rad when it is warm.
