What does T/A stand for ?
Dan V
01-16-2007 12:27:52
I am new.What does T/A stand for?
Genep
01-16-2007 18:18:59
 Re: What does T/A stand for ? in reply to Dan V, 01-16-2007 12:27:52
You are out plowing with your ole Super M TA and you hit some really hard clay. With a normal M you would have to shove in the clutch, cuss a little and shift down to second. With the TA you can pull back the lever, without clutching, get more power, and keep on going unitl you reach softer ground. It slows your ground speed and increases your power. I grew up with an MTA in 1967, wish I had it back. Traded it in for a 706 with the German diesel. Still have the 706
Gene
Janicholson
01-16-2007 17:02:15
In addition to the info below, Try searching in the back topice "search For" above. There is a welth of info on TAs and other topics. Good reading. Welcome to the IH Farmall Forum. JimN
JUG
01-16-2007 12:33:02
Torque Amplifier
Dan V
01-16-2007 12:36:25
 Re: What does T/A stand for ? in reply to JUG, 01-16-2007 12:33:02
What is that and what does it do?
Nat 2
01-16-2007 14:00:45
 Re: What does T/A stand for ? in reply to Dan V, 01-16-2007 12:36:25
The TA is a 2-speed powershift transmission that allows the operator to downshift on the fly to a slightly lower gear if he runs out of power or needs to move at a slower speed due to crop or field conditions.
There are two types of TAs, the original mechanical TA, and a hydraulically-operated TA that is used on larger tractors.
If you ever get a tractor with a TA, remember: Don't run down a hill with the TA lever back, and don't pull the TA lever back while going downhill.
bshannon
01-17-2007 06:15:00
 Re: What does T/A stand for ? in reply to Nat 2, 01-16-2007 14:00:45
The TA does freewheel downhill on the older Farmalls, but this is not the case with the 06 and newer series of Internationals.
K Sampson
01-16-2007 12:48:04
You pull the lever to engage the TA and it gives the tractor a lower gear without using the clutch to shift.
