Propper term: clamps for implements?
Mike Gibson
01-16-2007 15:30:14
Hi folks,
I'm needing to find a set of the clamps that go around the axle housing to enable you to connect implements or a hitch to the tractor. The problem is that I must not be using the correct terms as I cannot find anything except for the wheel/axle clamps when I do a Google search! What are they called and does anyone have a set for sale or know somewhere I might find some?
Thanks,
Mike
Mike Gibson
01-17-2007 07:37:05
 Re: Propper term: clamps for implements? in reply to Mike Gibson, 01-16-2007 15:30:14
Thanks Gordo. I had seen them but they didn't look like the others I'd seen. The only ones I'd seen were "diamond" shaped in the center. These look like they have 1/2 the diamond and 1/2 of a circle (like a muffler clamp. Could be just a bad photo or position.
Take Care,
Mike
SuperA-Tx
01-17-2007 09:21:51
 Re: Propper term: clamps for implements? in reply to Mike Gibson, 01-17-2007 07:37:05
I had to go look and see what yall were talking about. The ones I saw were diamond shape in the middle. Heres the item number at ebay - 300069105093
Ill try and post a direct link if it works.
GordoSD
01-17-2007 05:48:25
Set for sale on ebay right now Closing in 5 hours. Search "farmall c clamps". Good Luck!
Gordo
Mike Gibson
01-17-2007 03:44:20
I've been asked which model we have. We have a 1949 Farmall C, if it matters.
Thanks all,
Mike
GAUU6
01-16-2007 15:59:36
The CaseIH parts catalog for the SM calls them Channel,attaching,drawbar assembly and clamp,attaching drawbar. Channel behind axel,clamp in front. parts # 51 718DXB &51 717 DA
