M overhaule
james braley
01-23-2007 13:18:05
wanting to overhaule a farmall M. should i buy an overhuale "kit" or what? overhaule kits are a lot of monney any way to save a buck.
El Toro
01-23-2007 14:12:20
 Re: M overhaule in reply to james braley, 01-23-2007 13:18:05
I would agree with Old on tearing the engine down. You need to measure the crankshaft or have
it measured at your local auto machine shop. To be sure you are going to have good oil pressure you need close tolerances on the rod and main bearings. The same on cam bearings. Those sleeves need to be measured too. If they worn beyond the wear limit I would install a new sleeve kit. Check that oil pump for wear too. You don't want to have to pull that engine apart the second time. Hal
old
01-23-2007 13:36:13
Take it apart first then buy parts. If you buy the parts before you open it up you will most likely end up with the wrong ones and then you have to buy even more of them. You might be able to get by with new rings, rod and mains bearing but on the other hand you might need a complete rebuild and you can't know that till you open it up and see how good or bad what you have is
