A Rim Same As B Rim?
City-Boy McCoy
01-27-2007 05:32:57
Howdy, Boys: Won't an A rim fit on a B wheel, and vicey-versy? I assumed they would but a guy told me they would not....? Thanks. mike
Hugh MacKay
01-27-2007 09:14:25
 Re: A Rim Same As B Rim? in reply to City-Boy McCoy, 01-27-2007 05:32:57
Mike: Are you talking front or rear rims. The rear will fit. There is a difference in front wheels and rims but I'm not exactly sure when it occured.
The early or non adjustable front rims basically sliped onto a shaped cast hub and 3 lugs not fastened to either hub or rim held the rim in place. The later front rims have 3 lugs rivited to rim and bolt to the hub. I don't think that change occured exactly at model change between A-B and SA.
Some even call what I'm calling early rim, the non adjustable wheel, and the later one an adjustable wheel. I've only ever had adjustable or the lug rivited to rim type. But then I've never owned an A, B or BN. I can tell you I have a neighbor with a BN and it has adjustable wheels the same as my SA and 130.
Now, if you didn't start off confused, you most likely are by now.
City-Boy McCoy
01-27-2007 05:58:02
I should have typed SUPER A instead of A. mike
gene bender
01-27-2007 13:16:25
 Re: A Rim Same As B Rim? in reply to City-Boy McCoy, 01-27-2007 05:58:02
They all will fit whether fronts or rears. Just remember the rears width could vary as several widths were available. The adjustable rims take a different hub. It has always been interersting why adjustable rims were put on the A with and adjustable axle. Must have been a supply deal when you look at daily production numbers. When you build 30 some thousand a year the supply of all the parts was quite a deal
john cub owner
01-27-2007 20:35:20
 Re: A Rim Same As B Rim? in reply to gene bender, 01-27-2007 13:16:25
also, don't forget the A used a cast rim on the right side for added weight, and a stamped one on the left.
City-Boy McCoy
01-31-2007 19:20:06
 Re: A Rim Same As B Rim? in reply to john cub owner, 01-27-2007 20:35:20
Thanks, but I'm asking about the rim - not the wheel center. mike
