h clutch housing
daniel gillespi
01-31-2007 04:07:54
I have removed the 6 bolts on the clutch housing where it bolts up to the transmission. There are two studs there to but i cant get them out. I have tried running a nut up on the threads hoping that it would pull out like the ones that hold the frame rails on b theese things wont budge. Is that what is holding the case fom caming apart at the tans??
daniel gillespie
01-31-2007 19:07:30
 Re: h clutch housing in reply to daniel gillespie, 01-31-2007 04:07:54
i am talkimg about where the cluch /hydraulic pump is locatedthe case that bolts to the transmission
Steven@AZ
01-31-2007 06:29:04
Did you get the bolts on the top of the bell housing? There is one hidden inside that you have to get to through the starter hole.
I've had good luck running a nut on those dowel pins, put a vise grip on and pound them out. Or you can get them to spin with an impact wrench to loosen them up as well.
D Slater
01-31-2007 06:40:31
 Re: h clutch housing in reply to Steven@AZ, 01-31-2007 06:29:04
Steve unless I'm mistaken its where center housing bolts to transmission he's posting about. 4 bolts and 2 dowel pins up inside housing and 2 bolts on outside.
Steven@AZ Oops!
01-31-2007 10:21:12
 Re: h clutch housing in reply to D Slater, 01-31-2007 06:40:31
I guess you're right. My reading comprehension wasn't so great this morning...
In that case I've never had that apart on my H and cannot offer any help. :o(
D Slater
01-31-2007 05:10:30
Those are alignment dowel pins and the pins are tight enough there sometimes to hold center housing to transmission. Most times if threads are not batered up you can tighten nuts down enough that they start pulling out or spinning in hole and they can be worked out. Or if housing is in a position to do it, use a block of wood and big hammer on each side at front of housing until you get a crack between housings. Warning housings will break if hammered to much. Can't remember for sure on a H, but on a M those holes go all the way in to transmission and oil will leak at the pins if there not tight enough. So sometimes you find sealer on them which makes them tighter.
ChadS
01-31-2007 07:32:46
 Re: h clutch housing in reply to D Slater, 01-31-2007 05:10:30
I usually run the nut on the pin just till it moves out a tad, and then back the nut off enough to get a pry bar between the nut and the engine plate and pry the pin out, or cut notches in a few flat washers and keep tightening the nut till they fall out. Just like the fellas said,, make sure the bolt inside the starter housing is removed. Its hidden in there! chad
D Slater
01-31-2007 11:04:33
 Re: h clutch housing in reply to ChadS, 01-31-2007 07:32:46
Chad I'm sure not with the majority here. I don't think he's unbolting at rear of engine. Hope he posts back and clears it up.
ChadS
01-31-2007 14:19:04
 Re: h clutch housing in reply to D Slater, 01-31-2007 11:04:33
Im pretty sure he is just pulling out the block,,, I talked with him last week or so,,, But hard to say,, Chad
Allan In NE
01-31-2007 04:23:35
Are you talking about the torque tube? The transmission is clear back in the rear end.
Not clear where you're trying to split; front of the tube or the rear?
Allan
third party image
Tom Windsor
01-31-2007 07:59:51
 Chains and stuff in reply to Allan In NE, 01-31-2007 04:23:35
Alan
I am seeing your chains...you are ready to go!
My question is, the lever for the pump, what is the hole for that is about half way down the lever? Mine does not have this...was this add on? What is it for?
Tom Windsor
Wayne Swenson
01-31-2007 11:23:57
 Re: Chains and stuff in reply to Tom Windsor, 01-31-2007 07:59:51
The hole under the Lift-All control lever is threaded; that is where we would bolt the lifting mechanism the hydraulic cylinder needed for the #27 mower.
JohnG(TX)
01-31-2007 10:46:38
Tom, I think the extra hole on the lever is for remote hydraulic control like on a cotton picker or something like that. Some of my M's have that, and some don't. I do know one of my M's was under a cotton picker, because I scraped the thing off of it.
Allan In NE
01-31-2007 08:16:35
Dunno,
Just an access hole. Thought they all had it.
Allan
JUG
01-31-2007 04:19:38
DID YOU REMEMBER THE BOLT BEHIND THE STARTER THOSE STUDS DO NOT HAVE TO COME OUT
daniel gillespie
02-01-2007 04:31:29
 Re: h clutch housing in reply to JUG, 01-31-2007 04:19:38
I all ready have the engine out the flywheel,clutch, pressure plate and hydraulic pump removed. I need to remove the big hollow thingy between the rear of where the engine bolts and attaches to the front of the transmisiion. The pice is right below the gas tank
