need a temp gauge
n.e. farmer
02-01-2007 15:07:55
Need an international part #1546480c1
this is an instrument cluster gauge for a 424 gas.
It's a water temp, oil and amp light all in one.
The oil and amp lights still work but the capilary tube for the temp gauge snapped.
the dealer want's $180.00 for the gauge.
I wanted to just put in a generic 2" water temp gauge but there is no 2" hole avalible in the dash, only a 1" hole.
any thoughts on were to get one for less? i tried e-bay. should I just bore the 1" hole out to 2"? I hate to cut anything that is original.
Bob
02-01-2007 21:43:41
 Re: need a temp gauge in reply to n.e. farmer, 02-01-2007 15:07:55
If you are a bit adventurous, you can repair your old temperature gauge for about $15.00. Here's how:
n.e. farmer
02-01-2007 18:36:55
That's a big X2.
I'll try it, sounds good.
Thank you
rocketman
02-01-2007 15:19:47
I agree with you, don't go cutting up that original dash. Get a piece of sturdy aluminum, about 1/8" thick, 2 1/2" x 3" long, bend it to an "L" shape 1/2" from one end, cut a 2" hole with a holesaw, and mount it where you'll be able to see it, but also where the screw holes you'll need won't damage the dash .... you may have to change those measurements, depending on where you'll need to mount it. I've done this a few times on some of my machines - it works great !!
