M starter
Boyd
02-05-2007 15:39:32
What would cause a starter to smoke after trying to start the tractor. Starter is 6 volt, tractor is 12 volt. Is it any thing I can fix? Every time I take a starter to the repair shop it cost 100 bucks. Many thanks in advance,,,,, ,,,,, ,,,,Boyd
Boyd
02-05-2007 17:34:52
 Re: M starter in reply to Boyd, 02-05-2007 15:39:32
Do they have manuals on this site or where could I find one? Thanks again Jim..... ..... ..Boyd
Janicholson
02-05-2007 17:54:02
 Re: M starter in reply to Boyd, 02-05-2007 17:34:52
Look to the left, Top item is manuals. Binders Books also has authorized reprints. JimN
Janicholson
02-05-2007 16:48:26
Use beyond reasonable (starters should be on for 20 seconds for every two minutes off), or they get hot. Internal shorts will cause it. Dragging armature from worn end frame bearings is the most common real fault. All can be fixed on the bench with a repair manual, and common tools. JimN
