SA Crank Pully
TWheat
02-09-2007 16:23:59
How do you get the crankshaft pully off a Super A??
Looks like a really tight press fit.
TWheat
02-10-2007 05:21:51
 Re: SA Crank Pully in reply to TWheat, 02-09-2007 16:23:59
Thanks guys, looks like I have some fabbing to do. I don"t have a time schedule so I"ll just take my time.Thanks again.
El Toro
02-10-2007 09:18:52
 Re: SA Crank Pully in reply to TWheat, 02-10-2007 05:21:51
third party image
Here's a sketch of that puller. Hal
Keith-OR
02-09-2007 18:50:11
 My Puller!!! in reply to TWheat, 02-09-2007 16:23:59
TW, here is what I used. I built this one after reading all the horror stories on trying to remove the pulley. I used my porta-power, but there are hydraulic jacks that will work laying on their side.HTH
Keith & Shawn
third party image
third party image
third party image
El Toro
02-09-2007 18:24:25
third party image
You need a puller similar to this using a hydraulic jack. It was built for the Cub, it can be modified to fit the SA. Hal
PS: I think Bigdog made this puller.
thumbanger
02-09-2007 16:33:28
I made a piece out 1/2 inch metal to go behind pulley to have something to pull on and used a three armed puller to take them off if you try to pull without something behind it you will break it.
gene bender
02-09-2007 18:32:02
 Re: SA Crank Pully in reply to thumbanger, 02-09-2007 16:33:28
thats what i did so far OK
