Switching from LP to gas on an M
MartinD
02-10-2007 14:24:16
I have a Farmall M that is currently on LP/Propane.The tank is leaking and i cant find another one.Is there any problems switching over to gas?I know ill have to buy the gas tank,intake,carb,etcc..Anything else i should do?
Owen Aaland
02-15-2007 00:32:17
 Re: Switching from LP to gas on an M in reply to MartinD, 02-10-2007 14:24:16
I have a good LP tank from an M that was scrapped. Located in MN so it could cost a bunch to ship it.
MartinD
02-11-2007 05:16:12
Thanks alot for the info.
Tractor Rehab Mann
02-11-2007 05:03:14
You could use fork lift tank mounted on front of tractor . where are you located . email for more information. BUBBA
thumbanger
02-10-2007 17:50:30
The LP engines are good as they are clean inside a lot of buyers try to get these tractors because LP runs so clean good luck on change over.
NDS
02-10-2007 16:29:39
I switched one over a few years back and essentialy all I did was switch tanks, also had to have another hood, carberatur, lines, etc. Used LP manifold and it runs OK, have never got it as smooth as I would like at half throttle no load (a little flutter)but idles good and runs good at full throttle.
