1/3 restoration
James braley
02-15-2007 10:05:40
I have a farmall m. its condition is wonderfull interally. But its rusted has a ton of grease all over. woundering if it would be worth just stripping it and painting it up just to make it look nice?
thanks james
GA Dave
02-15-2007 18:39:12
 Re: 1/3 restoration in reply to James braley, 02-15-2007 10:05:40
True Red. But if his has as much grease, dirt, gunk, etc as mine did you gotta clean it to see where it comes from. David.
CRUSADER
02-15-2007 13:58:41
Why not get a steam cleaner or pressure washer after it. It should clean up fairly easy and quick (with a little luck).
Jim
georgeky
02-15-2007 10:21:33
They are wonderful old tractors and real work horses. If all it needs is cleaning, sanding and painting It is a worth while project.
Red48m
02-15-2007 10:19:03
Why not? Just do yourself a favor and atleast fix all the leaks/weeps the tractor has first.
