140 no oil pressure after rebuild?
BIG RED 1
06-25-2007 14:14:38
Hi could use some advice.Finally got the 140 running and but no oil pressure registering in new gauge(gauge is good )even running for 10-20 seconds.Filter is filling but housing isnt getting warm.
Any ideas as to what I need do as always thanks in advance
Janicholson
06-26-2007 10:50:31
 Re: 140 no oil pressure after rebuild? in reply to BIG RED 1, 06-25-2007 14:14:38
Check the archives on this, recent no oil pressure info will help. JimN
El Toro
06-25-2007 17:07:33
Did you prime the pump in a container of clean engine oil before installing pump on engine.? I hope you had the block dipped and all oil passages
cleaned of any sludge and dirt. I wouldn't run the engine until you determine the problem. Is any oil reaching the rocker arms? Hal
jonnny2006
06-25-2007 15:51:35
take the gauge off and see if she is squirting oil out the tube. they plug somtimes. i know mine did. i took it off and reved it up and POP it went and out come black gold as jed would say. and this aint beverly hills!
