os6 oil leak
Hand Crank
07-03-2007 13:26:56
Finally finished restoring my os6 & drove it in the parade the other day.When I got home I noticed that it was seeping oil around both brake drum shafts.Must be a seal of some kind??Is this problem a hard one to fix? Thank`s Don.
CNKS
07-03-2007 16:59:18
 Re: os6 oil leak in reply to Hand Crank, 07-03-2007 13:26:56
Not much of a problem on the M, don't know how easy they are to get to on the W/O/OS6. You have to remove the covers, the brake bands and drums, and then pry or pull the seals out. Do not try to remove the housings the seals fit into as they are bolted to the inside of the trans/diff housing.
