Mc-D 10-20 Tractor Drives
Big Red Man
07-04-2007 18:51:04
The only uses for my McCormick-Deering 10-20 are parades and tractor drives. The front tires are pneumatic--no problem. The rears are steel with the lugs removed. I'm thinking of cutting old pneumatic rears and bolting them on. Sound workable? Other ideas? Also to have enough speed for a tractor drive, I'm wondering about a truck rear end, a transmission and then using the pto to travel fast enough (6 to 10 mph) for a tractor drive. Suggestions/other ideas? Are (used) overdrives available for the 10-20's? Thanks for the ideas.
F-Dean
07-05-2007 08:25:21
 Re: Mc-D 10-20 Tractor Drives in reply to Big Red Man, 07-04-2007 18:51:04
How about someone organizing a "Low Speed" Drive for us slow pokes. I would love to go on a drive with my W-30 but at 5 MPH, I can't keep up!
Big Red Man
07-05-2007 08:34:23
 Re: Mc-D 10-20 Tractor Drives in reply to F-Dean, 07-05-2007 08:25:21
Guess what? I think that's a great idea! Do you live anywhere near central Texas?
Bob Kerr
07-05-2007 09:06:48
 Re: Mc-D 10-20 Tractor Drives in reply to Big Red Man, 07-05-2007 08:34:23
That is a good idea! a slow drive! If I lived close to Tx I would be there with the F-12 but you guys might leave me in the dust! I do have a road gear for it but it needs bearings bad.
Bobcat
07-04-2007 19:19:35
Cutting the center part out of a set of tractor tires works well for parades. I have done a couple tractors that way and found that a chain saw is about the easiest method. But be carefull it is quite dangerous! Do a little at a time and be prepared for a mess to clean up and a blade to sharpen. Try to get them as tight on the rim as you can while useing carriage bolts to hold. As for making a 10-20 fast enough for tractor rides good luck. The brake band would not be very good at stopping if you do rig up a way for speed! There was a high speed option for W-30's but I think the transmission and brake was alot different. I hope this helps You!
Big Red Man
07-05-2007 08:16:58
 Re: Mc-D 10-20 Tractor Drives in reply to Bobcat, 07-04-2007 19:19:35
Thanks, Bobcat & Bob Kerr, -- good info & advice. I'm gonna take the suggestions and avoid tractor drives as I live in the Hill Country of Texas and the brakes are probably a problem. Maybe plow days. Maybe an old fashioned, pto-driven, pull type shredder? Maybe cut some farmers/ranchers pastures. I'm just trying to think of how/when I can use the first tractor ever owned by my family. It was bought jointly by my three uncles, all of whom were born in early 1900's & now long gone, but the tractor is still here. Thanks again!
Bob Kerr
07-04-2007 19:51:01
Threre were road gears for 10-20s, but good luck, they only came on trators with pnumatic tires and I don't think many came like that. In fact I just looked it up and only on late 1938 and 39s and it is listed as a "special 4 speed trans". the newest 10-20 I ever saw was a 1935. everyone I have seen have either steel wheels or cut offs and I have seen a bunch of them. Come to think of it I did see one with the original spoke wheels, but that was it. I talked to a guy the other day who said something about driving a Regular or F-20 with the PTO but said it would flat out fly down the road. I don't think I would want to be on the seat of one with just rubber tread bolted to it going 15-25 MPH driven off the PTO. Also after using my 10-20 in hill country, Bobcat is right on about the brakes. even without getting some grease on the band, there is the brake fade problem. I am a big 10-20 fan and would have loved to take mine on a drive, but I also would not want to put myself or others at risk. My 10-20 would get a lot of attention at plow days, even made the newspaper with it a couple times, That might be something to consider or try to find a 38-39 10-20 with the 4 speed.
