i'm NOT stumped
james in mo
07-06-2007 09:48:59
i took a look at the air filter today. 3/4 inch of sludge cleaned it out and put new oil in it. the M starts e-z and re-strats good. do ya think this is the main problem. or??
John-Paul T
07-06-2007 10:28:52
 Re: i'm NOT stumped in reply to james in mo, 07-06-2007 09:48:59
Forgot to add running like that could have made it sooo rich it was = to holding choke on and flooding engine. Which will be hard for the starter to crank since the cylinder/s are filled with fluid.
Starter could be bad, but time will surely tell.
John-Paul T
07-06-2007 10:26:15
Well ya! I mean all internal combustion engines need proper air flow and metering to properly run. When the air cant get in the intake, its gonna be starved for air which is = to running engine way rich.
janicholson
07-06-2007 10:25:08
Two ideas, It may have contributed, and it could be that something you wiggled when doing it was actually the cause.
I think a starter draw test (cheap gauge from auto store) might show a styarter needing bushings. It is ok at 450 amps bad at 600. The starter can be affected by heat, and be OK when cold, and draggy when hot/warmed up. JimN
james in mo
07-06-2007 12:27:14
 Re: i'm NOT stumped in reply to janicholson, 07-06-2007 10:25:08
i dont think the starter is bad because we jumped it with 12 volts and it start either. the thing i dont understand is why its start so e-z the first time??
james in mo
07-06-2007 12:30:16
 Re: i'm NOT stumped in reply to james in mo, 07-06-2007 12:27:14
i ment to say it didnt start either
old
07-06-2007 09:56:20
It might have been some how if they don't breath well they don't run well
