6vdc to 12vdc positive ground
Arlo
07-12-2007 13:35:21
1948 'M' Farmall . Wanting to go to 12v battery for a little more cranking power during winter. Would like to have a wiring diagram, to do this right. Have 12v generator, regulator, 12v battery. Dose it need a 12v coil also. And what about the resistor. How do I tell what size is needed for it. Thanks for any help we get.
gene bender
07-13-2007 03:09:21
 Re: 6vdc to 12vdc positive ground in reply to Arlo, 07-12-2007 13:35:21
The ground will be determined by the regulator check it out to see which ground it is made for it could be marked on the bottom. The generator doesent care which ground is used.
Bus Driver
07-12-2007 17:18:03
I see that you want 12 volt positive ground. That is a rarity and equipment for that is not widely available. Not low cost either. Why that choice?
Arlo
07-12-2007 19:41:29
 Re: 6vdc to 12vdc positive ground in reply to Bus Driver, 07-12-2007 17:18:03
Bus Driver: It wouldn't neccesary have to be positive ground. Not sure how to wire it for neg ground either.
Yugrotcart
07-12-2007 17:04:10
Arlo,
Bob M's wiring diagrams will help you out.
Here's a link,
Paul
Arlo
07-12-2007 19:47:01
 Re: 6vdc to 12vdc positive ground in reply to Yugrotcart, 07-12-2007 17:04:10
I'm thinking that the 12 volt would be wired the same as the 6 volt. Only difference would be to use 12 volt compinents.
