Value of 656 D Hydro that needs Help!
migraine
07-12-2007 18:25:20
Local John Deere dealer called to see if couple of us I.H. guys might be interested in 4 tractors he took in on trade for 1 good newer JD he had on the lot . The older gent died and left this pile of iron for his wife and daughter to deal with. There is an old H which should be parted out but dealer thinks its worth a Thousand bucks. No way around here. Then there is a 986 which does run but has led a rough life and shows scars to prove it. Thinking 4000 for that. Next is a 186 Hydro with 2350 loader with front wheel assist. Supposedly the tractor runs good and the trans. is fine but the gears are stripped in the FWA? The loader has one weld on it but overall is not too bad. No value placed on that one yet. The last is a 656 Diesel 282 Hydro with very nice wide front, nice flat top single light fenders, very nice sheet metal and all emblems. Front tires are new and back ones are 20 percent. The motor is fair to good although no one has heard it run because the hydro went out five years ago and the old gent thought he could fix that a minute. Well he got it apart ok and then realized he was in way over his head so there it sets with all the lines off and wires everywhere and parts strung out in boxes and various places. Dealer wants me to make an offer on the 656 but I don't think its worth more than 800 or a thousand is it?
Allan In NE
07-13-2007 01:50:50
 Re: Value of 656 D Hydro that needs Help! in reply to migraine, 07-12-2007 18:25:20
Yeah Migraine,
I could sure use that tractor.
Since it is in pieces, betcha if you wave $500 in front of him, he'd be all over it. :>)
Allan
Owen Aaland
07-12-2007 22:57:05
Much as I hate to see good tractors parted out, it be be the best thing for the 656. You don't know just what was wrong before it was taken apart nor how much more damage has occured from sitting disassembled for five years.
If I got it in this condition I would probably put it all back together so the problems could be determined. If it needs plates and pistons you're looking at a lot of money. If it is a stuck relief valve or a cracked high pressure line then the repairs would be resonable enough to justify repairs.
IaGary
07-12-2007 19:55:33
Good evening migraine.
Don't tell Allan where it is or he'll be after it for the engine.
You could probably part it out and make money at that price.
Gary
