M Farmall Pto
Big un
07-14-2007 16:57:14
Hello all. I have a 1950 M that the pto will just fall out of gear.Even under a load like bushhogging.Is there any adjustment? It just pulls up and stops at the little stop pin,right.Any help would be appricated.
Thanks
Bigun
Owen Aaland
07-14-2007 19:12:04
 Re: M Farmall Pto in reply to Big un, 07-14-2007 16:57:14
There is a detent ball and spring on the inside of the lever. This spring may be rusted off or the ball may be stuck. If the shift lever moves without being able to feel any detent, this could be the reason.
Janicholson
07-14-2007 17:41:14
There is a spline based clutch in the exposed part of the PTO unit. It may need to have a new sliding collar and shaft to fix it. If when putting it in gear, it just barely engages teeth, it could be the control fork, or the linkage. caseih.com has a parts diagram on line, follow the parts, start searching for parts here link on the caseih site. JimN
