140 woes
Tab
07-23-2007 10:08:04
Used my 140, and it jumped out of gear 3 times(in first, pulling a plow). Re-did the 3 spring and balls in shifter housing(with new kit), and think that may have solved the problem there. Noticed the other day that my hydraulic fluid housing box was a little loose. I stood on the rear lift arm assembly and saw the block(in front of the battery box) move a little. Tightened the 4 bolts down and think we're o.k. Do these bolts need frequent checking for tightness? Thanks.
georgeky
07-23-2007 12:23:27
 Re: 140 woes in reply to Tab, 07-23-2007 10:08:04
That should be a very rare thing. Maybe you should install new lock washers. Every time I remove or tighten a loose bolt I put new lock washers on. Have never had a hydraulic unit come loose in many hours of working them.
SuperA-Tx
07-23-2007 11:04:28
I have never checked those bolts on our 140's. I might now that you mentioned it.
