Diesel Engine Conversion on an M
Wicksfield
07-23-2007 12:58:13
Does anyone know of a diesel engine conversion for an M? A 4-cyl. Cummins would be cool but you'd have to watch the horsepower rating so as to not tear up the driveline.
Rootsy
07-24-2007 05:57:01
 Re: Diesel Engine Conversion on an M in reply to Wicksfield, 07-23-2007 12:58:13
Have an M with a 2-71 Detroit in it sitting in the shed... in need of quite a bit of work.
GM and Shepard at least made conversion kits for the M's to use their engines in.
markloff
07-24-2007 10:24:05
 Re: Diesel Engine Conversion on an M in reply to Rootsy, 07-24-2007 05:57:01
Interested in selling it? Where are you located?
Mark
markloff
07-23-2007 13:11:21
I'm just finishing up a 2-71 Detroit Diesel in a Super M. Should put out around 65hp@2100rpm and about 58hp@1800rpm. I'm a mold maker/CNC machinist by trade and I did the whole thing from scratch. You have to make a new rear cover for the engine and a crank spacer that allows you to use the stock flywheel/clutch and starter location. It turned out to be a lot of work. More than I thought but that is the way it usually goes!
Mark
