Removng International 454 Final Drive
Bob Patrick
07-23-2007 13:01:58
I recently purchased a International 454 diesel at an auction and now trying to fix several problems I have discovered (nothing major to this point).
I am trying to remove the final drive by removing the tire and 11 bolts securing it to rear frame. However I am unable to wrestle it loose from the rear frame.
Is there something I have missed? Any help will be greatly appreciated.
Dave in Southern IL
07-23-2007 15:06:44
 Re: Removng International 454 Final Drive in reply to Bob Patrick, 07-23-2007 13:01:58
I am not familiar with the 454 but I recently replaced a brake seal on my 424 and in order to accomplish that you must drain and remove the hydraulic housing, drain the differential housing and remove the bull gear which is attached to the end of the drive axle by either a bolt or a snap ring. It is not a hard job but messy and time consuming. I think that the two tractors are similar enough that you would have to follow the same procedure as I did.
Bob Patrick
07-25-2007 13:24:50
 Re: Removng International 454 Final Drive in reply to Dave in Southern IL, 07-23-2007 15:06:44
On the 454 the manual I have only shows removing the wheel and bolts attaching axle to frame. I don"t see any bolts or snap ring at the wheel end of the axle. I have a chassis manual on order which may be a better source than the one I currently have.
Thanks!
Bob Patrick
07-25-2007 13:24:38
Thanks!
