Farmall 300 regulator
Russ in KS
07-24-2007 20:00:45
Why would the ammeter go clear to discharge when using a jumper wire between the bat and gen terminals on the VR.
Tom43
07-25-2007 10:10:46
 Re: Farmall 300 regulator in reply to Russ in KS, 07-24-2007 20:00:45
Dear Russ,
This situation is perfectly normal. When you touch a jumper from the battery terminal to the armature terminal(correct way to polarize a generator) you have completed two parallel circuits to ground. One is through the hot brush through a couple of bars of the commutator, then out the third brush through the field windings to ground. The other is through the hot brush and through the series wound armature windings to the ground brush to ground.
