Oil leak @ belt pulley on Farmall C
Justin S. - TX
07-29-2007 16:10:33
When i am mowing I develop a leak at the shaft for the belt pulley. The oil is yellow and cloudy so I know there is water and it needs changing. I put in a new oil seal but the leak persisits. My uncle has an identicat tractor with a protector on the shaft and he tells me it seals this shaft. Do I need this or the pulley or is there another seal that is bad?
Slappy
07-30-2007 02:49:48
 Re: Oil leak @ belt pulley on Farmall C in reply to Justin S. - TX, 07-29-2007 16:10:33
I haven"t been into the pulley on my SC, but two things I have found out about seals on rotating shafts are 1) if the shaft has a groove worn into it by the seal, or 2) the shaft has any side play in it,you will likwly have a leak. A speedi-sleeve (sp) can be pressed over a groove in the shaft to fix it (check with your bearing house). If you have side play you have to identify any worn parts and replace them. Some of the others on the board may have more ideas to check out. Good luck.
georgeky
07-29-2007 17:50:01
You still have a sealing problem as the protector sleeve does not seal it. I have two with bare shafts and neither leak.
Larry in GA
07-29-2007 17:38:57
Justin
The book shows a flange w/oil seal,and an oil seal both after the outer bearing on the belt pulley shaft.
Larry
