identifying a Mccormick Deering Tractor
BARRY BURKE
08-01-2007 06:10:23
I am trying to identify a Mccormick Deering tractor with no I.D. plate. We believe it to be about a 1929 15-30 but this is a guess.I have pics available.There is a date stamp on top of tran. case which is 8.25.29 There is date stamp on lh side of eng toward rear lower corner which is 9.18.29 On r.h. side of block at front top corner is a raised oblong casting with the no.12794 with possibly a 3 and 7 at the end.If anybody has knowledge of how to I.D. I sure need help. Thank You!!!!! !!!!!
Nebraska Cowman
08-01-2007 10:38:55
 Re: identifying a Mccormick Deering Tractor in reply to 350 HU Don, 08-01-2007 06:10:23
Probably. Serial numbers for 1929 15-30 are 99926 - 128236
If it has a double compartment fuel tank (the front smaller tank was for water) and a water pump it is a 15-30. The 10-20 looks similar but has no water pump and in 1929 used a single fuel tank with a small round gasoline starting tank behind it. 1929 serial numbers for 10-20 are 119823-159110
Give me some part numbers from the main castings and I can tell you for sure.
BARRY BURKE
08-01-2007 13:59:37
 Re: identifying a Mccormick Deering Tractor in reply to Nebraska Cowman, 08-01-2007 10:38:55
Thanks for replying, I appreciate it very much
tractor has double tank, frt one smaller, also has a starter tank,round & about 2 qt. size sits in back of fuel tank. casting no's as follows
eng. block 585-D BELT PULLEY HSG. COVER
ex. mamifold 589-D 4625-DA
tran. cover 768-D TRACTOR DOES HAVE strg. gear 650-DA WATER PUMP
strg. wheel 7410-TA
frt. axle 4486-D
russ hamm
08-01-2007 10:32:31
 Re: identifying a Mccormick Deering Tractor in reply to BARRY BURKE, 08-01-2007 06:10:23
Late 1929 22-36 barry. A good old tractor in my opinion.
