Wiring a Farmall A
History Guy
08-02-2007 17:49:36
I am restoring a 1944 Farmall A and having problems wiring with the new aftermarket wiring harness. It has a green, grey, and purple wire that splits into two black wires. What components does each wire go to?
Is it true that a Farmall "C" water pump can be added to an "A?"
Thank you for your time!
history guy
08-02-2007 19:56:28
 Re: Wiring a Farmall A in reply to History Guy, 08-02-2007 17:49:36
Here is the link for the wiring harness on E-bay.
Krumholz
08-02-2007 19:40:02
Is it a magneto type or a battery and distributor type. 6V or 12 V. Pos or neg ground. There is a world of difference in all these situations. The wire color doesn't mean much except to the harness manufacturer. Expand and get lots of help.
history guy
08-02-2007 19:53:55
 Re: Wiring a Farmall A in reply to Krumholz, 08-02-2007 19:40:02
it is also a 6 volt
history guy
08-02-2007 19:45:12
It is a magneto with a positive ground. The guy I bought it off of had the wiring all screwed up so I have never seen one wired correctly. The harness just doesn't seem to fit correctly. I got it off ebay. Here is a link to it.
Link
Thanks for your help!
Will Sick
08-02-2007 19:36:46
The drain plugs on the water pumps for an A and C are at a different angle. Some pumps have two openigs and can be used on both. Others do not.
history guy
08-02-2007 19:46:18
 Re: Wiring a Farmall A in reply to Will Sick, 08-02-2007 19:36:46
I have a C113 engine. They make water pumps for that?
CNKS
08-02-2007 19:20:49
You need the diagram in the operator's manual. I have had simlar problems with a wiring harness for a 460U. One wire goes in and does not come out. The engines in the C and A are the same, so the water pumps fit both. Water pumps on either were not standard but an option. You can compare diagrams and part numbers on www.caseih.com to confirm this.
