Lift all Seal
Dave from Texas
08-06-2007 09:35:07
I am trying to replace the seal on a Farmall H lift all system, but I can't get the coupling off. How do you get it off? Is it a press fit, splined, etc.
Wayne from MN
08-06-2007 21:01:34
 Re: Lift all Seal in reply to Dave from Texas, 08-06-2007 09:35:07
Drain oil, remove Lift-All from tractor, remove pump from housing, insert flat iron in pump, rotate coupling "lefty-loosey" to remove. The coupling will self-tighten when back in operation so no need to try & tighten too much.
Temporarily put the lever on while aligning the pump when assembling.
neblinc
08-06-2007 10:19:46
The coupler is normal thread, you will need to "jam" the fins with something like a large brass punch or flat stock. It will then unscrew.
When I did mine I used a large punch that just fit in the slot on the coupler and tapped it loose.
Do a search for "belly pump" in the Farmal forums for more ideas.
Randy
GeneMO
08-06-2007 13:48:59
 Re: Lift all Seal in reply to neblinc, 08-06-2007 10:19:46
The book says to take a 1/8" piece of flat stock and put it between the gears. I think 1/8" by about 3/4. Whatever fits between the teeth. Do not use a hardened punch as it will mark or scar the teeth ( trust me I know this first hand) There is an opening on the top that will let you insert this flat stock. I am not near the pump or book right now but doing this from memory. Once you have the gears locked with the flat stock you can insert a piece of square stock in the coupler and break it loose. Dont remember which way it turns.
Gene
