1566 no 1st gear
abk
08-07-2007 22:17:10
My 1566 will not move in 1st gear, does not matter high or low.
Clutch free travel /brake / ta linkage has been adjusted (by me).
I have a cab on it and the dealer said a lot of $$$ to tear into it just to see what the problem is.
What gives??
abk
08-13-2007 14:07:21
 Re: 1566 no 1st gear in reply to abk, 08-07-2007 22:17:10
Well, whaddaya know, the 1st gear is back. I just sort of 'caressed' it in, after going from 3rd to 2nd and then to 1st.
Kevin Meier Iowa
08-08-2007 14:17:43
will it move in 2nd gear. If i remebmer right the same adapter runs both 1st and 2nd gear? Gettting the cover off with a cab is tricky too. The steering column has to be moved to get to the cover
abk
08-08-2007 15:20:59
 Re: 1566 no 1st gear in reply to Kevin Meier Iowa, 08-08-2007 14:17:43
Yes, 2nd and 3rd are no problem, and if I pause long enough to let the tranny stop it does not grind, either. First, however, I have not been able to get for a while. Shift handle moves easily including in and out of 1st position...
Kevin Meier Iowa
08-08-2007 17:00:36
 Re: 1566 no 1st gear in reply to abk, 08-08-2007 15:20:59
if you have 2nd gear then my guess would be that you have a bad gear or shaft problem
abk
08-08-2007 09:16:11
Thanks ohjeffoh and tv!
I will try to get as far as I can with the top cover (shifting forks and whatnot), and then probably off to the repair man it goes!
ohjeffoh
08-09-2007 05:15:00
 Re: 1566 no 1st gear in reply to abk, 08-08-2007 09:16:11
Drain the hy-tran and take the bottom cover plate off. use a crow bar or something to pry to see if the shaft moves.if this is the problem it will move a good bit.
ohjeffoh
08-08-2007 05:46:23
Sounds like the nut is off the counter shaft, if so using it this way will cause major damage and be very costly repair.
abk
08-08-2007 08:19:19
 Re: 1566 no 1st gear in reply to ohjeffoh, 08-08-2007 05:46:23
Ugh... can this be fixed through the speed tras. top cover i.e. without the Big Split?
the tractor vet
08-08-2007 09:00:19
 Re: 1566 no 1st gear in reply to abk, 08-08-2007 08:19:19
While i am no expert on the 1566 as in my area i only know of one 1566 and one 1568 and have never been into that three speed but i do know that it will require the BIG split to do anything other then work on the top cover . And being the fact that it has a cab unless ya are set up with the splitting stands and cab supports and all the rest of the neat toys to play with i am sorry to say that you are at the mercey of the man that does.
