o/d of M exhaust Pipe
e-manhunt
08-10-2007 06:35:47
I need to get a sleeve to hold the muffler onto the exhaust pipe. My manual is with the tractor 6 hours away, but i want to buy the sleeve here before I leave for the farm this evening. Anyone have an idea of the outer diameter of the exhaust pipe on an M?
Thanks in advance.
RustyFarmall
08-10-2007 09:27:27
 Re: o/d of M exhaust Pipe in reply to e-manhunt, 08-10-2007 06:35:47
The pipe that is on it now is apparently burned and eroded away. It will be virtually impossible to find a sleeve or shim that will fill the gap and allow the muffler to fit as it should. I suppose you might be able to wrap that pipe with some flashing or maybe even aluminum foil but that repair will not be satisfactory and will have a very short life span. The only real cure is to replace that pipe. The other responders have described what you need. The only other thing I will say is that when you get ready to do that job, be prepared to spend a minimum of 1/2 day doing it, and you will need a 2" pipe tap to recut the pipe threads in the manifold.
Janicholson
08-10-2007 07:10:40
Sorry Wardner, I looked it up (because 1/8" walls seemed thin. 2" NPT 11-1/2TPI is 2.375 nominal OD. JimN
e-manhunt
08-10-2007 09:10:27
 Re: o/d of M exhaust Pipe in reply to Janicholson, 08-10-2007 07:10:40
Thanks guys. It shouldn't be a difficult finding a piece, but as i get older, finding the time to find the piece of pipe becomes the problem.
Wardner
08-10-2007 07:54:58
OK Jim, I stand corrected. I was too lazy to look it up or go out to the barn and measure. All e-manhunt has to know is 2" NPT. Who among us doesn't have a piece of that laying around or installed somewhere?
Wardner
08-10-2007 07:02:29
If your manifold is setup with pipe threads, a 2" NPT (National pipe thread) nipple will be the size. If you have a dual fuel manifold with chimney, I would assume the OD is the same. I believe that 2" NPT is about 2.25" OD. If not, exhaust bushings are available from a automotive parts house.
