SM Trans
pete_5959
08-11-2007 07:46:56
Starting to put this transmision back together. Sure wish I was the one who took it apart. My question is....Is there suppose to be a gasket on the rear axle frame assy and the large and heavy transmission cover? Thanks in advance for the info.
MN Scott
08-11-2007 10:54:04
 Re: SM Trans in reply to pete_5959, 08-11-2007 07:46:56
The top cover gasket for the Super M is 1981227C1 $38.90. The rear axle carrier gasket 47670DB $11.61. These are the current CNH part numbers and prices. Click on the link below. You can access the online CIH parts books and prices from there.
City-Boy McCoy
08-11-2007 13:23:52
 Re: SM Trans in reply to MN Scott, 08-11-2007 10:54:04
Scott: Thanks for catching that. I guess the part number on the Case/IH/NH online parts catalog is wrong for the super M. mike
CNKS
08-11-2007 06:59:05
 Re: SM Trans in reply to City-Boy McCoy, 08-11-2007 13:23:52
The part numbers are not wrong, CIH uses the latest versions of the parts catalog, which for that tractor are 50+ years old. Many of the part numbers have changed. Although the parts fit, some bear little resemblence to the originals -- seals and gaskets fit in that category. The CIH site does not update them, but the dealers computer does. Apparantly Messicks does, also. I haven't looked at Messicks site lately, I probably should before I get any more parts, to avoid "sticker shock".
City-Boy McCoy
08-11-2007 07:09:47
 Re: SM Trans in reply to CNKS, 08-11-2007 06:59:05
I know. I was trying to be kind to MN Scott - hoping he would notice and find out for himself, without me telling him he was wrong. I don't know where he got the number. I looked at Messick's and it was the same number as what I quoted. mike
NDS
08-12-2007 10:23:42
 Re: SM Trans in reply to City-Boy McCoy, 08-11-2007 07:09:47
Mike: You are both right when you search for the 49056DB number it comes up as Case gasket but click on the Case gasket and you get a shopping cart screen that has bright Red block that says nunber supercede by 1981227C1.
D Slater
08-11-2007 08:04:24
Looked at invoice that I think was last time I bought gaskets to fit his tractor. Number I used and is same on invoice was 361368R4. Punched that # in site posted and it came up $41.24. I thought 23.06 was high when I purchased several.
City-Boy McCoy
08-11-2007 15:55:05
 Re: SM Trans in reply to D Slater, 08-11-2007 08:04:24
Beats me. It seems we're all coming up with different numbers for a Super M top cover (deck) gasket. mike
CNKS
08-11-2007 07:20:41
I will retract part of my statement then without looking at the Messick's site. Perhaps he ordered the parts from Messicks, and is using the actual part number on the packaging, or bought them locally. The letter C in the number indicates that the number has changed, or no R or D suffix. My CIH parts guy always says it crosses to a different part number, I suppose because he thinks if I get the new part with a different number, I will think it is wrong. But, I would guess that about 1/3 to 1/2 of the parts I buy are that way.
D Slater
08-11-2007 08:12:33
 Re: SM Trans in reply to CNKS, 08-11-2007 07:20:41
Looks like the time of our posts is messed up.
NDS
08-11-2007 12:58:25
Like georgeky I must have been robbed my dealer is not known for being cheapest place around but is usually not far out of line. Thanks for the link good source.
georgeky
08-11-2007 11:19:37
They must have gotten cheaper or my man stuck it to me. I gave 80 bucks for one 10 years ago.
NDS
08-11-2007 09:16:40
The transmission cover gasket is a little pricey if my mempry is correct about $70 several years ago.
georgeky
08-11-2007 08:54:13
Get ready, that gasket is quite high. I think the last one I bought was around 80 bucks.
NDS
08-11-2007 09:19:41
 Re: SM Trans in reply to georgeky, 08-11-2007 08:54:13
You beat me by a couole of minutes your post was not showing when I started to one finger type mine.
georgeky
08-11-2007 10:28:43
 Re: SM Trans in reply to NDS, 08-11-2007 09:19:41
That happens all the time. There is plenty of room for all replies. I am a slow typist and slow thinker sometimes as well. Then sometimes I don't think much at all.
City-Boy McCoy
08-11-2007 08:03:32
Pete: Cover gasket: #358843R1; Rear axle carrier housing gasket: #47670D.
You can go to caseih.com and look up these parts yourself. When you do, you will see nice diagrams which may be of help in putting things back together. You can print them out. Good luck. mike durhan
Patrick Martin
08-11-2007 12:18:15
 Re: SM Trans in reply to City-Boy McCoy, 08-11-2007 08:03:32
Permatex Grey RTV sealer is just as good in these areas and a whole lot cheaper.
