Farmall 300 Hydraulics
Andy Motteberg
08-20-2007 14:03:45
Hi, My Dad's 1956 Farmall 300 with live pump leaks the hydraulic oil from the metal lines that are on the transmission cover next to the battery box. When it leaks, there is oil all over the transmission cover and is a big mess. If you add hydraulic oil again, it just leaks it all out. We have used it a little with no oil in the pump, not very much though. Is it bad for the pump to run it that way? If it is, does anyone have hydraulic lines for this tractor?
Thanks,
Andy.
georgeky
08-20-2007 16:08:29
 Re: Farmall 300 Hydraulics in reply to Andy Motteberg, 08-20-2007 14:03:45
Andy, shoot me an email. I have that line.
CityBoy-McCoy
08-20-2007 16:06:34
Andy: Like SDE implied, you'll ruin the pump with no fluid in it. Hopefully, you did not run it long enough to do it harm. mike
Andy Motteberg
08-20-2007 16:10:47
 Re: Farmall 300 Hydraulics in reply to CityBoy-McCoy, 08-20-2007 16:06:34
It has not been run long like this, my Dad did not use it much since it had that problem.
SDE
08-20-2007 14:28:55
The pump is lubricated by the fluid in the reservoir. No fluid, no lubrication.
SDE
LenND
08-20-2007 14:19:01
We had a 400 with the same problem. The dealer took it in and replaced the lines. He said some of the 300 and 400's had pipes that cracked and then leaked. This was 1956 that was bought new and started lesking soon after.
Andy Motteberg
08-20-2007 14:31:15
 Re: Farmall 300 Hydraulics in reply to LenND, 08-20-2007 14:19:01
I think the lines are rusted through because I removed the line shield and there was lots of wet dirt, leaves and mouse junk under that shield and the lines are a little pitted.
