Popping noise in new front tires
David Goode
08-25-2007 13:33:33
I Finally got two new front tires and put them on this morning, They are working great but I have one little problem, there is a strange "popping" noise coming from the right front tire. I noiticed the rim was bent where the noise seems to be coming from. Is this a problem? should I take the tire off and bend the rim? or can I drive the tractor the way it is. It is a Super M and has a 2000 loader on it which I use off and on to carry implements and dump snow. Thanks for any help. -David Goode Coggon, IA
David Goode
08-25-2007 18:12:33
 Re: Popping noise in new front tires in reply to David Goode, 08-25-2007 13:33:33
O.K thanks for the replies, I'll recheck all the bolts tomorrow. Thanks again. -David Goode Coggon, IA
Allan In NE
08-25-2007 14:56:29
David,
You have a loose lug. Recheck and retighten.
Allan
El Toro
08-25-2007 14:44:05
I agree with Jim, check the bolts. Hal
Janicholson
08-25-2007 14:04:00
Bent rims (if not structural) on a M are not a problem, noise is. It is probably a bolt that is tight from bad dirty or damaged threads. Check the bolts. JimN
CityBoy-McCoy
08-25-2007 14:55:45
 Re: Popping noise in new front tires in reply to Janicholson, 08-25-2007 14:04:00
Loose?
Janicholson
08-26-2007 08:47:26
 Re: Popping noise in new front tires in reply to CityBoy-McCoy, 08-25-2007 14:55:45
Tight from junk threads, not tight from compressing the rim loop to the hub. Tight in feel, loose in fact. I was being a little too loose in my explanation. JimN
