F-20 wheel's,
Kir in ks,
08-28-2007 14:16:00
can anything be done with the F&H wheel's on farmal F's, This one i know about has a rotted spot halfway down the frontside of left wheel rim,
can they be welded back together, and cleaned up so they ;look ok,?
I sure hope so,
as Id really like to get this tractor home , and start in on it,
Ron in Nebr
08-28-2007 21:36:38
 Re: F-20 wheel's, in reply to Kir in ks,, 08-28-2007 14:16:00
I've got a set of the F&H round spokes with a couple rust through spots on one rim too. Asked a friend of mine who used to manage a Goodyear store about them, he said heck yeah, he used to weld patches back in rusted spots all the time. Gonna be doing mine sometime, havent done 'em yet. Be sure to silicone an extra patch of rubber or something over your weld beads to keep 'em from rubbing through the tube.
James Williams
08-28-2007 19:22:14
Kir,Been there and done that,Look around there is F&H wheels out there,Just bought 1 for My F14.
Maark
08-28-2007 17:39:32
www.detwilertractor.com They will rerim round spoke rims. front and rear..
russ hamm
08-28-2007 15:13:03
Hey kirk. Are those demountable, or round spokes you have? We have had to splice rims some in the past on the round spokes. The trick is to not remove all of your weld if you can. Sometimes we can grind down the outside and leave some more inside for strength. We actually welded two halves of a rear b farmall wheel to make one, cutting across the wheel. Came out good.
kirk in ks,
08-28-2007 15:26:11
 Re: F-20 wheel's, in reply to russ hamm, 08-28-2007 15:13:03
Hi russ,
yea their round spoke's there russ, and as i was saying,, the back half of the left wheel on the front side's all rotted out,
(split out from sitting out in the weather eveidently,)
kirk
