How to remove draft spool assembly?
Tom in Mo.
08-28-2007 14:44:36
I have a 424 and broke the draft spool while pulling a cultivator. The IT manual says to remove it during control valve overhaul but doesn't say HOW to remove it. I have the entire control valve assembly out of the hydraulic housing and the control valve head off. I think I need to drive the spool assembly out from the back and out the front face. Can anyone verify this? Case/IH part number for the spool is 304908R91
IH item number 54
IT item number 23 and 24 page 66
thanks in advance
georgeky
08-28-2007 16:08:00
 Re: How to remove draft spool assembly? in reply to Tom in Mo., 08-28-2007 14:44:36
I broke my draft spool in a 444 I had, and I bought a complete lift unit from a salvage yard cheaper than the spool was from IH and just swapped the whole deal. Lot easier and cheaper and it worked fine until I sold the tractor. That spool was 400 dollars when I needed one.
