Cracked Hydraulic Pump Model H
momsworry
08-28-2007 16:42:03
I have a 51 H that has a cracked hydraulic pump that leaks. Does anyone know where I could find one that isn't cracked and for how much? Thanks.
47M
08-28-2007 17:59:20
 Re: Cracked Hydraulic Pump Model H in reply to momsworry, 08-28-2007 16:42:03
I had the same problem with the Liftall pump on my '47 M this spring. The crack in mine was about half way along the high-pressure passageway for the left rear outlet (the one on the pump back plate).
I ended up using carb cleaner to remove the oil residue from that passageway, screwed a plug into the end of it, then mixed up 3 tubes of JB Weld and filled/plugged that passageway completely. I let it cure overnight, re-assembled and installed the pump, it's been working fine with no leaks or problems since. (I only use one hydraulic outlet, so having only two working outlets isn't a problem for me.)
I don't know if just the pump back plate is still available anywhere, but even if it is, I doubt I could get if for the $15 it cost me for the JB Weld. The only whole pumps I could find, including this site, sell for at least $700.
Mitch
