capacity trends
karl f
09-12-2007 23:24:47
noticed in the last couple years when looking at new equipment specs that hydraulic system fill capacities are going down. it's insane in a way, since you now have a 50 gpm capable machine that only holds 8 gallons! not like the old 06-56 series where 20-40-or more gallons barely hit the add mark! they must be utilizing coolers moreso than we're used to, and internal lube pumps. it's a little easier financially on those new operators to actually change the oil with such a small quantity. how many of us are guilty or know someone that's guilty of just changing the filter?
amazing the older stuff took such abuse.
karl f
ran outta 685 topics for the evening/wee hours of the morning ;)
Hugh MacKay
09-13-2007 02:36:39
 Re: capacity trends in reply to karl f, 09-12-2007 23:24:47
Karl: I'm betting these new tractors will require more replacment parts and much sooner than those 06, 56, 66 and 86 tractors did. One just has to go back to 00 and 30-50 series, small reservoirs and low oil created more problems than oil contamination ever did. Small reservoirs create an element of surprise, just how quickly the hydraulic oil becomes low, and low oil creates heat. Heat spells trips to the parts counter
