timing issue
bm3501466
09-13-2007 13:22:20
I have a 301 in a 460. I have the 460 governor on it. It will only run about 2000 rpm wide open. How many degrees does it need to be timed at since it isnt running 2640 wide open. Thanks
K.B.-826
09-13-2007 21:12:31
 Re: timing issue in reply to bm3501466, 09-13-2007 13:22:20
Since you haven't got any other answers yet, I'm going to guess and say use 460 dist. and use 460 specs. I base this upon the fact that you are running at 460 speed with a 460 governer. If you run the 301 dist, you're gonna be throwing off the advance curve, since it was usually rated at 2640.
