international 3414 3 pt hitch
keith smith
09-29-2007 17:57:35
hi again
posted earlier about my 3 pt hitch not working. found out some more
info. i do have good presure going to control valve. i pulled one
large plug next to the plug for the orfice screen to check presure.
none at all, even at full throttle. wondering what my next step should be.
thanks keith
Fromjb2
09-29-2007 18:37:55
 Re: international 3414 3 pt hitch in reply to keith smith, 09-29-2007 17:57:35
Hi Keith, I believe the large plug that you pulled was where an aux remote outlet would be installed and there will be no flow there unless the isolating valve is closed. Isolating valve is controlled by the knob at your right hand on the hydraulic valve body below the front of the seat. When the isolating valve is closed the flow is diverted from the 3pt to the aux remote port and is still controlled by the 3pt lever but the 3pt hitch will not work. The left hand knob controls the flow rate to the 3pt, selects either 2.5 or 5 gpm to the 3pt. I have a B414 Operator Manual that has a simple diagram of hydraulic flow.
If you email me at clarabrownlee@rogers.com, I can scan a couple pages for you.
JimB
